GRAND C4 PIC 120 EAT6
MessagePosté le: Mer 18 Avr 2018 - 13:29    Sujet du message: GRAND C4 PIC 120 EAT6 Répondre en citant
Ligne de produit C4 PICASSO (B78)
N°APV/PR 14276 FV 2 0555
Date de Début de Garantie 31/12/2015
OPB 006Q
NRE e2*2007/46*0356*10
P4A 9807591099
LIGNE DE PRODUIT C4 PICASSO (B78)
SILHOUETTE BREAK LOISIRS
FINITION HAUTE HAUTE
MOTEUR DIESEL TURBO DV6FC FAP 88KW
TRANSMISSION BVA 6 RAPPORTS TYPE STT
TYPE DE PEINTURE METALLISEE VERNIS
COULEUR DE CAISSE KKS - PEINTURE MOKA
TYPE D’HABILLAGE INTÉRIEUR GARNISSAGE CUIR NAPPA "8Q"
COULEUR DE GARNISSAGE "FD"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVA AT6
DEFINITION A VENIR ANCIENNE GAMME
MOTEUR (TYPE) MOTEUR TYPE DV
MONOGRAMME BLUE HDI
COUPLE TACHYMÈTRE SANS COUPLE TACHYMETRE
ALIMENTATION INJECTION TURBO ECHANGEUR DIRECT
DÉPOLLUTION (MOTEUR) DEPOLLUTION (MOTEUR) EURO 6.1
CYLINDRÉE 1600 CM3
CATALYSEUR CATALYSEUR INF 50PPM
RÉSERVOIR DE CARBURANT RESERVOIR CARBURANT AVEC DETROMPEUR
MOTEUR REFROIDISSEMENT RADIATEUR 28DM2 - EP18 ALU BRASE
RÉCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ CARTER
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR" + ECHANGEUR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE EURO6
VENTILATEUR 1 VENTILATEUR 2 VITESSES 95W AERO
CHAINE DE TRACTION HYBRIDE SANS CHAINE TRACTION HYBRIDE
STOP AND START AVEC STOP AND START ALTERNO DEMARREUR
COUPLE RAPPORT COUPLE PONT 15 X 58
STYLE ROUE JANTE AQUILLON 17"
JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R17 95V RENFORCE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT SANS LOCALISATION
BOITE DE VITESSES TYPE BVA AT6 3
BARRE ANTIDÉVERS ARRIÈRE RAIDEUR 30000 NM/RAD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAMETRE 23 CREUSE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
ANGLE VOLANT AVEC CAPTEUR ANGLE VOLANT
SUSPENSION (TYPE ARCHITECTURE) SUSPENSION METALLIQUE
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRIQU ASSISTE DOUBLEPIGNON LOW POWER
ANTENNE ANTENNE + GPS + GSM
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEUR LATERAUX AVEC BAS DE MARCHE CHROME
PROTECTION SOUS CAISSE SANS PROTECTION SOUS CAISSE
FEU DE SIGNALISATION BALISAGE LATERAL
ETANCHÉITÉ AÉRODYNAMIQUE ETANCHEITE AERODYNAMIQUE PORTE AV ET AR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE AVEC MEMOIRE
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT + PASS ROUE + GMP AC
ESSUIE-VITRE AVANT INTERMIT 2 VIT+CAD AUTOMAT
PARE-CHOCS PARE-CHOCS AV CC + JONC CHROME ET PC AR CC
PLAQUE POLICE SANS PLAQUE POLICE
PORTE-BAGAGES MONTAGE AVEC BARRES DE TOIT LONGITUDINALES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD AVEC CORNERING LIGHT
ROUE DE SECOURS SANS ROUE DE SECOURS
ACCESSOIRES EXTÉRIEURS POIGNEE EXT NOIR + JONC CHROME
VITRE (ASPECT) VITRE TEINTEE + SURTEINTEE
VITRE (TYPE) P-B FEUILL ATHER+ACCOUS + AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES ACCES AVANT + COFFRE + DEMARRAGE MAIN LIBRE
APPUI-TÊTE ARRIÈRE APPUI TETE AR ARTICULE SOMMEIL
ASSISE SUPPLÉMENTAIRE 2 SIEGES SEPARES SUPPLEMENTAIRES
DETECTION ANGLEMORT AVEC SURVEILLANCE ANGLE MORT
CACHE-BAGAGES CACHE-BAGAGES + TENDELET
CEINTURE DE SÉCURITÉ AVANT ENROULEUR REVERSIBLE + ALARME CONDUCTEUR ET PASSAG
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
CLIMATISEUR AVEC AEROTHERME
COMMANDE DE VITESSES COMMANDE VITESSE AU VOLANT
CONSOLE AVEC CONSOLE AMOVIBLE
EXTRACTEUR D’AIR EXTRACTEUR AIR STANDARD
MIRROR LINK SANS MIRROR LINK
ECLAIRAGE RANGEMENT AVEC ECLAIRAGE BOITE A GANTS
ECLAIRAGE DE COFFRE VOLUME CHARGEMENT CDE AUTO ECLAIRAGE COFFRE + VOL CHARGEMENT + AMV
EQUIPEMENT PLANCHE DE BORD DECOR PLANCHE DE BORD EXCLUSIVE
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR HABILLAGE EQUIPEMENT INTERIEUR CUIR
FEUX INT. DIVERS ECLAIRAGE LEDS
TABLETTE DE TRAVAIL AVEC TABLETTE TRAVAIL
GARNISSAGE VOLUME CHARGEMENT TAPIS COFFRE MOQUETTE
RANGEMENT SOUS SIÈGE SANS RANGEMENT SOUS SIEGE
COMBINÉ (CARACTÉRISTIQUES) COMBINE NUMERIQUE 29 VOYANTS
GARNISSAGE DE PORTE DECOR VERNIS BRILLANT
PULSEUR ADDITIONNEL AVEC PULSEUR ADDITIONNEL
INSONORISATION HABITACLE INSONO TABLIER + TUNNEL HAUT DE GAMME
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV A MEMOIRE CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT + RELAX
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR ELECTROPNEUMATIQUE
RÉGLAGE ASSISE AVANT PASSAGER REGLAGE LOMBAIRE PASSAGER
RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER
BOITE DE RANGEMENT TRAPPES DANS PLANCHER
AFFICHEUR ECRAN DGT TACT+DALLE 12" DFT
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
NAPPE CHAUFFANTE SIEGES CHAUFFANTS
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIED CONDUCTEUR + PNO PORT
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGERS AV/AR
PLAFONNIER CDE PORTES AV+AR PLAFONNIER AV+AR
RÉCEPTEUR RADIO RECEPTEUR RADIO SMEG ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE PROGRAMMABLE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INTERIEUR JOUR-NUIT ELECTROCHROME
RANGEMENT (AUTRES) AUMONIERE FILET
SURTAPIS (ASPECT) SURTAPIS MOQUETTE 1
TUNER-RADIO BI TUNER RADIO
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV AR + CAMERA AR+PK AUTO
STORES LATÉRAUX STORES LATERAUX COMMANDE MANUELLE
SURTAPIS SURTAPIS AV + AR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VARIANTE ASSOCIÉE ASSISE VARIANTE ASSOCIEE ASSISE HAUTE
SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
ECRAN VIDÉO ARRIÈRE SANS ECRAN VIDEO AR
RÉTROVISEUR INTÉRIEUR SURVEILLANCE ENFANT RETROVISEUR INTERIEUR SURVEILLANCE ENFANT
PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + USB
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME EVOLUTION 2.0
ALTERNATEUR ALTERNATEUR ISTT41
BATTERIE BATTERIE L3 760 VRLA2 EN AGM
ECLAIREMENT PARTICULIER FEU DIURNE AVANT (DRL)
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION 433,92 MHZ SUPER HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE FULL
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES TRIPLE
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
EQUIPEMENT DE SECOURS KIT ANTI CREVAISON
MessagePosté le: Mer 18 Avr 2018 - 13:29    Sujet du message: Publicité
FJ898657
MessagePosté le: Mer 18 Avr 2018 - 13:47    Sujet du message: GRAND C4 PIC 120 EAT6 Répondre en citant
shinta85
KILOMETRAGE: 344080
MessagePosté le: Sam 21 Avr 2018 - 07:41    Sujet du message: GRAND C4 PIC 120 EAT6 Répondre en citant
Déposer un client ,c'est effectuer une livraison?
C'est une illusion d'optique ou les sièges sont bas par rapport au plancher?
De belles heures de routes en perspective en tout cas. Okay
MessagePosté le: Mar 24 Avr 2018 - 19:37    Sujet du message: GRAND C4 PIC 120 EAT6 Répondre en citant
Bravo Ricou !
Merci pour cette préz... tu changeras de couleur dans ton avatar. Mr. Green
Je ne suis pas monté dans celui là mais dans le blanc (destroy), plutôt bien assis. Bon, rien à voir avec nos C5, tout de même...
MessagePosté le: Sam 7 Juil 2018 - 23:21    Sujet du message: GRAND C4 PIC 120 EAT6 Répondre en citant
00009734R7 HUILE BOITE DE VITESSES AUTOMATIQUE 43.97 EUR   52,76 EUR   52,76 EUR
MessagePosté le: Aujourd’hui à 12:59    Sujet du message: GRAND C4 PIC 120 EAT6
